Home > Technical (L322) > Fitting an after-market stereo to Range Rover P38
madalex123
Im about to buy a new head unit for my P38, as the original head unit has given out, can anyone offer me some advice, any extra's or adaptors I need to Buy.
Cheers Alex
Post #51106 21st Feb 2011 1:01am
hi alex, welcome to the FFRR forum..i notice you're asking questions bout a p38 on a FFRR forum [2002 onwards], but i'm sure a previous p38 owner will come and give you some relevant advice.. ... - .- -.
Post #51113 21st Feb 2011 9:00am
comports
Hi Alex,
First question - Did you have the Harmon Kardon upgrade kit in your P38 with DSP amp? If so, there are a couple of options.
1st - you will have to bypass all that kit as there are door amps in each door to power up the speakers. A standard stereo will not work using this lot. You could go the route of adding resistors in line to bring the power output down but it's a faff.
I added a Kenwood flip screen to my P38 (with Nav, Bluetooth, DVD, TV etc) using the low output cables and this works fine fine. Any single din unit will work and you can get the standard RR to ISO connector leads from AutoLeads.
Quick Tip if you do have the dsp fitted and go via the low output route - Using the old Head Unit, setup the dsp to however you like it (volume, spacial setting etc) as you will not be able to alter this once you connect the new HU. The dsp does however remember your setting so you still benefit from the settings used before you disconnected the old one.
2nd - If you don't have the HK upgrade and dsp then it's an easy swap out for standard singe din units. Same Autoleads cable will be required though.
Hope that helps but plenty more info on rangerovers.net. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #51121 21st Feb 2011 9:19am
