Transmission oil thermostat coolant leak | |
Hi all.
After changing the water pump, radiator, thermostat and top hose, i've got one little coolant leak left. Someone in the past was well aware of these leaks and everything was welded together with K seal or similar. Since i've cleaned it all up, i've obviously exposed another leak.
Seems to be coming from the transmission oil cooler thermostat. The connection with the clip in it just above where the top hose pipe clips on. It's a constant drip like a dripping tap.
I've outlined in red on the picture.
 | Click image to enlarge |
I can't find any info on the web. Is this fixable by dismantling and sticking a new o-ring in it or is it a new thermostat job?
Thanks very much
