Home > For Sale & Wanted > 19 inch wheels with Vredestein Wintrac 4 Extreme tyres
rory
Wheels in very good condition and tyres have less than 1000 miles of use
Note these wheels fit over Brembo calipers if required
£850 or very near offer.
Light kerbing on this wheel only
Cheers
Rory
Post #51077 20th Feb 2011 9:28pm
Japseroony
England 2019 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Just a point to note, they wont fit over the 2011 Brembos as these are bigger due to the new engine - sorry. "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #51122 21st Feb 2011 9:42am
rory
Thanks - didn't know that.
Not sure if they would fit on a 2010 5.0 SC either.
So to be safe - will fit over Brembos on either the 3.6 TDV8 or 4.2 SC.
Cheers
Rory
Post #51635 23rd Feb 2011 8:58pm
dan_uk_1984
And FYI you can get weights that stick inside the wheel rather than are crimped on the outside. Looks a bit neater. That sounds like an a-hole comment but its not meant to be! Thumbs Up
Post #51636 23rd Feb 2011 9:03pm
Dan, not wanting another argument tonight but it has been explained to me by an expert wheel balancer (That I trust) that the reason those weight lips are there is that to balance a wheel (properly) you need some of the weight on the outside and when all of the weight is hidden inside the balance is never perfect. Thus the reason most LR 19" have a "Weight rim" on the outside (and 20" + style wheels will never be perfectly balanced)Very Happy
Post #51655 23rd Feb 2011 10:36pm
dan_uk_1984
Why only the 19's and not the 18's or 20's? After all, your balancing the tyre, not the wheel.
The weight's that are added to balance the plane of the wheel (lateral wheel wobble), so for example if you want to balance by putting 5g on the front/outer of the wheel. You would put 7.5g on the inside edge - think lever effect.
If you are balancing an axis difference then you put it dead centre opposite side.
Rim weights are about 1/4 of the price, they also require no surface prep. Where as the sticky weights need a nice clean surface to stick properly. Generally one only see's clip on weights on steel wheels.
There is plenty of info on the interwebs about this...
Post #51658 23rd Feb 2011 10:53pm
Plenty about UFO's and the US not going to the moon on the Interwebs too.....
It is just remotely possible that experts in their chosen fields may know more than you Dan. After all 20" and above wheels are fashion orientated and Fashion does not allow for external weights my friend.
nb: I meant 19" and lower sizes as you well know.
Post #51661 23rd Feb 2011 11:00pm
dan_uk_1984
So LR make cars with wheels that can't be balanced? Not sure I buy that.
I really don't know what your problem is lately, but you can get off my back!
Post #51662 23rd Feb 2011 11:05pm
Dan,
Not sure why a difference in opinion on a topic makes you think I am "on your back" but I can assure you that I am not and have supported you an many occasions as you well know (and in some cases when you did not know).
I discussed this subject when balancing some wheels with a guy I believe to be an expert and he showed me on his machine why outside and inside weights were required to get a "Perfect" Balance. As you know I am not a mechanic so cannot give full details but its safe to say he was making perfect sense to me at least.
Land Rover are becoming increasingly "Style" concious and are perfectly capable of putting style before substance if means greater profit.
I was really not saying you cannot balance 20" + rims just that in the opinion of this expert you cannot achieve "perfect" balance that's all.
Now cheer up and have a drink. Thumbs Up
Post #51664 23rd Feb 2011 11:17pm
a 'static' balance is perfectly acceptable ..static being only balancing the inner rim lip..
you can also balance an alloy by putting stick-on weights on the inside of the wheel as close as you can to the inner rim edge and as close as you can to the outter edge , both weights obviously being hidden inside...
i say this with 24 years tyre experience.. ... - .- -.
Post #51685 24th Feb 2011 9:32am
There that's you all told .................... Ner Ner
Post #51688 24th Feb 2011 9:39am
