Home > Wheels & Tyres > Which size tyres for 22” wheels
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Been looking at some 10x22 wheels with a +45 offset for my L322.
Would I have any problems with 285/40/22? Most people seem to use 285/35/22 but I’ve worked out that it’ll give a much smaller rolling radius to the standard wheels. Taking into account tyre pressures I’m expecting the 40 profile tyres to be about the same circumference as standard.
Post #485645 10th Aug 2018 4:19pm
alistairh
I have 285/40/22 continental on mine . No issues at all
Post #485649 10th Aug 2018 4:46pm
Full Fattie
That looks excellent, that’s my mind made up, I’ll be going for them. Would you say they have protected your wheels ?
Post #485654 10th Aug 2018 6:05pm
alistairh
I changed from the 35 to the 40 when I got the new turbines . I haven’t damaged any in a year on potholes ect.. my last 22’s were scrapped as they kept cracking with the 35..
Post #485666 10th Aug 2018 9:15pm
Full Fattie
That’s my worry, I don’t want to crack or damage them in any way.
What did you do about TPMS on the new wheels?
Post #485938 13th Aug 2018 11:53am
Not that it’s entirely relevant, but 275/40/22 are the standard size for the L405
Post #485951 13th Aug 2018 1:15pm
Full Fattie
What width are the L405 wheels with the 275 tyres?
Post #485953 13th Aug 2018 1:25pm
Bronjen
United Kingdom 2002 Range Rover Autobiography 4.4 V8 Baltic Blue
285/40/22 are perfect for two reasons, they give the correct rolling radius for 22 inch wheels on RR and the 40 profile gives more protection from curb and pothole damage for the wheels.
I have them on my D3, Which is a heaver car and my current L322, please see below
The magic number you need to keep in mind is 31.0 inch, so your speedo stays accurate.
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
255/60-19 6.0in 15.5in 31.0in 97.5in 650 0.0%
275/40-20 4.3in 14.3in 28.7in 90.0in 704 -7.7%
275/40-22 4.3in 15.3in 30.7in 96.3in 658 -1.2% Tyre looks narrow on RR especially with any wheel
over 9 inch wide
285/35-22 3.9in 14.9in 29.9in 93.8in 676 -3.8% Tyre offer little protection for rim from pot holes etc
285/40-22 4.5in 15.5in 31.0in 97.3in 651 -0.2% Tyre offers better protection for rim due to taller side
wall and is correct diameter, fills wheel arch very well needs 10 inch wide wheel
295/40-22 4.6in 15.6in 31.3in 98.3in 645 0.8% Tyre is slightly larger and is within speedo
tolerances needs 10 inch wide wheel
Hope that helps Whistle
Post #486221 15th Aug 2018 8:30pm
Really ????
I thought the standard diameter for the L322 was 30" - that's what a 255/50/20 would be.......
The standard width of the L405 22's is 9.5
Post #486227 15th Aug 2018 8:53pm
alistairh
@full fattie mines is a 2004 plate but I’ve facelifted her . Car doesn’t have tpms system yet. I’m working on that one
Post #486230 15th Aug 2018 9:03pm
Full Fattie
The wheels I seen were 10” wide although they’re the same style as yours but copies. I’ll probably go 285/40/22 for that width.
Post #486583 19th Aug 2018 5:07pm
Full Fattie
Ended up going for 285 40 22. I was tempted by a 45 profile but it was going to increase the overall size by more than I was prepared to go with. This size seemed like a good size for rim protection and was good for a 10” wheel.
Just need some wheels to wrap them around now. Probably go for turbines but not sure on colour yet.
Post #487576 30th Aug 2018 3:03pm
