Home > Technical (L322) > My FFRR Has Disgraced Itself Today
AJGalaxy2012
Now pretty hacked off, I bought a new removeable tow ball for my new to me Rangie and was looking forward to a few days away. Tow ball arrived special delivery, the right one so i fitted it, went to storage to pick my caravan. All went well until I went to plug in the lighting. Look at the state of the wiring, it's a wonder there hasnt been a fire.
Do any you good people have details of which fuses and where cover the standard towbar, looks like im going to have to spend some time on this. Routing of the cables would be nice to know too so I can splice a new one in.
Many thanks in advance.
J BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #486861 22nd Aug 2018 7:36pm
Shocked
Hard to think what would have even caused that
In terms of routing, My cables ran through the spare wheel well
Post #486862 22nd Aug 2018 7:42pm
rjff
J
Was the tow bar frame fitted and the electrics when you bought the FF and can I assume you did not fit the electrics?
On our 11MY TDV8 the connector for the tow electrics is in the wheel well, against the rear bulkhead on the nearside. It's a grey multi pin fitting. We fitted the Westphalia bar and a 13 pin socket which simply goes through the FF hole into the wheel well and pugs in. You can then use a 13 pin plug or a splitter to give you two outlets, a 7 pin for vehicle lighting and the other for charging/powering the 'van. I assume that any other manufacturers bar simply uses the same type of electrical fitting.
If your FF is the same then you should be able to replace the wiring, links may help.
https://www.pfjones.co.uk/pfjoneswiringkit..._09-09.pdf
https://www.pfjones.co.uk/land-rover-range...506pf.html
Richard
Post #486866 22nd Aug 2018 8:09pm
AJGalaxy2012
Re: My FFRR Has Disgraced Itself Today
Unnecessary quote removed
Thanks for that I'll get on it tomorrow. BMW i3 Electric Car
Post #486868 22nd Aug 2018 8:26pm
AJGalaxy2012
The bar was already there with the sockets, a square hole in the middle to receive the fitting the the removable Westfallia tow ball. I purchase those items new because the one supplied was seized solid and no way was I risking the towball falling off with 2 tonnes of caravan in tow.
If I can find the car end of the wiring and disconnect it whilst i arrange new 12n / 12s or a 13 pin socket that would be brilliant. I'm quite happy to do the wiring, I just need to identify the fuses that are sure to have blown.
Thanks for your help, I will keep you updated.
Post #486869 22nd Aug 2018 8:30pm
rjff
Great J
Let us all know what you find and how you fix it.
Cheers
Richard
Post #486870 22nd Aug 2018 8:30pm
rjff
J
Page 1 of this thread may help
http://www.fullfatrr.com/forum/topic25908.html
Picture hopefully attached. It appears it may be fuse 20, rear load area, offside, behind the removable panel
Richard
Post #486872 22nd Aug 2018 8:37pm
AJGalaxy2012
I think it's going to be quite a mess, I just hope it's not damaged any modules involved. BMW i3 Electric Car
Post #486873 22nd Aug 2018 8:38pm
AJGalaxy2012
rjff wrote:
J
Richard
Thanks for that I'll have a look and check it all out, I may as well upgrade to 13 pin plug at the same time.
Post #486874 22nd Aug 2018 8:41pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Worth changing to a 13 pin. IIRC there are at least 3 fuses to do with tow electrics, 2 in the boot and 1 in behind the glove box.
I’ve changed all 3 at various times.
Ian
Post #486893 23rd Aug 2018 7:55am
AJGalaxy2012
Thanks Ian, I think thats where I'm heading, I'm all prepped for swapping the caravan over to 13 pin so I may as well do the rangie now. BMW i3 Electric Car
Post #486894 23rd Aug 2018 8:34am
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Rodents? David
Please let me know if my comments upset you, I may wish to upset you again.
Post #486913 23rd Aug 2018 12:17pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Remember that 13 pin Euro socket has to work at MoT time - it is checked as part of the test.
Twin 7 pins are not checked
Post #486923 23rd Aug 2018 2:45pm
Depends whether yo consider the MOT check a good or bad thing.......
I’d buy a pre wired and resin filled 13 pin socket and make the connections inside the car.
Post #486925 23rd Aug 2018 3:05pm
AJGalaxy2012
It had definitely been on fire the wiring behind the plugs. Ive traced the wiring to the connector in the sapre wheel well and having replaced three fuses now have appropriate lighting signals. Just need to trace out the fridge, battery charge and rev light signals and can wire the new socket.
Hell of a mess.
 BMW i3 Electric Car
Post #486930 23rd Aug 2018 4:14pm
