Home > Maintenance & Mods (L322) > Side Light / Indicator / Illuminated tread plate Connector
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
Hi there. I purchased a set of illuminated tread plates off a user here and I'm finally getting around to retrofitting them, I need the power connectors for them and have been reliably informed that they are the same as the side indicator connectors.
Does anyone have a source for two of these with a bit of wiring on them (don't have the tools to push pins etc...) Current Vehicles :
L322 2010MY TDV8 Autobiography
BMW E38 735i
BMW E63 645ci
Post #486587 19th Aug 2018 5:41pm
Do you have a pic of what you need sir?
Post #486621 19th Aug 2018 11:33pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Sorry to go off on a tangent, but I just replaced mine as only the drivers one was working at all and that was only half working.
The new ones are really dim and effectively invisible in anything other than pitch black. The LED puddle lights probably don't help, but I'm wondering if there is something wrong with them? I'm sure the bit that worked on the original ones was brighter. 2010 4.4 TDV8 Vogue SE
Post #486628 20th Aug 2018 6:48am
Eric Cartman
sadly not at the moment, but ill take a pic of the other side of the connector on the illuminated tread plates if that helps ? Current Vehicles :
BMW E38 735i
BMW E63 645ci
Post #486964 23rd Aug 2018 8:41pm
