Home > Maintenance & Mods (L405) > Steering Wheel Lock
Gibby
2013 Range Rover SE 4.4 V8 Causeway Grey
Steering Wheel Lock
Does anyone use one and have any recommendations? Or is someone going to get through them pretty quickly if they want the motor?
Gibby[/u]
Post #485668 10th Aug 2018 10:26pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
I'd recommend DiskLok. I researched quite a bit.
Yes, given enough time a prof thief will get through most things, - all you can do is try and delay, delay and delay them some more as the risk becomes not worth it to them. They will move on to the next one. Disklok, seemed to slow them down the most. It's solid, chunky and a heavy weight well built.
If you go for it, you need the medium size one to fit the steering wheel of a RR. - I would also get the steering wheel glove with it to protect if you have a fancy steering wheel.
Post #485685 11th Aug 2018 8:32am
