Home > Technical (L322) > Eas abs reset tool
Sandyt
Mine has twice lost sync with itself ie wouldn't start and had to roll back the CCM - might not have been the only solution but it worked and both times in foreign lands so 11d tool more than paid for itself Thumbs Up
Post #486038 14th Aug 2018 7:23am
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Never had that problem or heard of it hope it stays that way .Did you try battery disconect to reset ecu?It's just the £400 that's off-putting
Post #486080 14th Aug 2018 1:55pm
Sandyt
Tried the battery disconnect it seemed the key had lost sync with the immobiliser but rolling back the ccm worked did this after speaking to the boys at GAP who were brilliant great support when in a foreign land
Post #486095 14th Aug 2018 3:17pm
rik
Mabe a new key?
Post #486135 15th Aug 2018 7:40am
Did you check the for sale section for 2nd user iiDTools ? Thumbs Up .
Post #486147 15th Aug 2018 9:45am
rik
Yes could not find anything suitable have just received carsoft and will get it up and running shortly a lot cheaper than is .£136 free delivery
Post #486152 15th Aug 2018 10:18am
rik
Should read iid predictive text again
Post #486153 15th Aug 2018 10:19am
rik
Ok so air suspension pipe repaired and reset with carsoft no prob easy to use .Saving money already 👍
Post #486184 15th Aug 2018 3:04pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Good fix Rik Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #486185 15th Aug 2018 3:43pm
rik
Post #486232 15th Aug 2018 9:13pm
rik
Oh and I wrapped some rubber underlay around pipe so it don't happen again
Post #486233 15th Aug 2018 9:17pm
