Home > Maintenance & Mods (L405) > How to undo L405 front grille?
pld118
Can anyone please advise?
I’m presuming that you need to remove, these 4 cap covers but how do you do so please?
Thanks.
Post #484592 29th Jul 2018 9:13am
Screwdriver in the slot and prise/slide the inner upwards then remove the four clips... You will then need a long flat screwdriver to twist the four push in clips at the bottom of the grille Thumbs Up
Post #484617 29th Jul 2018 2:13pm
The lower clips are very similar to those found on a 322 Grille... Shown in this video Thumbs Up
Post #484618 29th Jul 2018 2:14pm
pld118
Thanks Craig, very much appreciated Thumbs Up
Post #484627 29th Jul 2018 3:37pm
Post #484632 29th Jul 2018 4:44pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Powerful actually have a video on the L405 grill Thumbs Up
 Cheers Ian
Kielder 4x4 Safari
Post #484636 29th Jul 2018 5:25pm
pld118
Thanks.
Craig’s explanation did the trick. It comes off and goes back on easilly, when you ‘know how’ and can then be confident you won’t snap anything Embarassed
Post #484637 29th Jul 2018 5:30pm
I don't much like the idea of hanging off the grille to try and "unpop" the clips! The use of a long pry bar is much more reliable Whistle Rolling Eyes
Post #484668 29th Jul 2018 10:09pm
