Home > Maintenance & Mods (L322) > Ac only blowing out passenger vents
Danwilderspin
Any ideas all wheels on coldest but I only get air con cold air out passenger two vents? Rear hot driver hot too... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #483991 21st Jul 2018 3:59pm
Paul thornton
Not sure but mines definitely cooler on the passenger side...
Post #483995 21st Jul 2018 5:46pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Happened to me when I had a slight a/c refrigerant leak. Seems to prioritise the passenger side. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #483998 21st Jul 2018 7:10pm
Danwilderspin
How did you find it? My friend was telling me that the x5s have motors which fail on them to switch ac to not ac wonder if this could be something similar? How did you identify the leak? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #484035 22nd Jul 2018 11:12am
Nomad
Took it to ATS. They have to check for leaks by law before refilling. They said no leaks found, refilled it. All fine for £40.
One month later same again. This time they didn't charge. No leak found. They said it might be a component e.g. compressor or condenser.
One month later same again. Took it to dealer as I have a warranty. They couldn't find a leak initially but eventually found it up near the bulkhead. They refilled and so far so good. That was two months ago so fingers crossed. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #484038 22nd Jul 2018 12:24pm
stu1
This may help: http://www.fullfatrr.com/forum/topic25732.html
Post #484088 23rd Jul 2018 12:01am
Danwilderspin
hmmm I don't think everyone is having what I am -
I found a 5 series post which deals exactly my symptoms and it looks like a software issue when its hot and humid. Unfortunately I can't seem to find a fix for the ff Sad
https://5series.net/forums/e60-discussion-...lem-28545/ Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #485316 6th Aug 2018 5:08pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Failed blend motors? There are 6 of them in there.... Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #485408 7th Aug 2018 5:57pm
Danwilderspin
Would that be the thing that used to chirp like a bird under the dash in the middle? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #485423 7th Aug 2018 9:08pm
Andy B
Re: Ac only blowing out passenger vents
How long since you had the system re-gassed? I had the same issue on the 405 (ie passenger side cool, driver and rear cooling, not cool). More info here :-
http://www.fullfatrr.com/forum/topic48202.html SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #485448 8th Aug 2018 9:30am
