Home > Technical (L322) > Upgraded from a p38 to L322 but have problems. someone help
ASH
United Kingdom 2011 Range Rover SE 4.4 V8 Santorini Black
Hi guy's,
Ive recently upgraded from a P38 diesel to a 2011 l322 diesel & having a few issues.. Can someone please help me out??
1, airbag light on (error code shows that the drivers frontal acceleration sensor fault)
2 Navigation shows that the map data cannot be read
3, Cruise control doesn't work (says that the radar sensor is blocked)
4, Ive downloaded some mp3's to a memory stick & plugged it in (in the armrest) & all is good but it will only play maximum of 10 seconds of each track & then skips to the next track. it does this on every track
Any help would be greatly appreciated.
Many thanks in advance..
ASH
Post #482669 4th Jul 2018 11:07pm
nino_nino
ASH<
mp3/USB you are in scan all mode, on the Audio/Video USB screen on the TOP RIGHT corner of the screen pres settings in the settings pres random all. after that you can list all folders, tracks and play them. Thumbs Up
Nino.
Post #482679 5th Jul 2018 8:47am
Navigation has a card in the top (below the dash mounted speaker) I can’t remember if you can access it from the speaker hole but that’s where it is sir...
Radar sensor is behind the front bumper skin...
Airbag system needs a well trained pair of hands to investigate further imho sir...
Welcome to the asylum sir Very Happy Thumbs Up
Post #482680 5th Jul 2018 9:58am
ASH
nino_nino wrote:
ASH<
Nino.
Ive just tried this & have the same problem
What does this card do?
Post #482706 5th Jul 2018 6:45pm
The card holds the maps sir Thumbs Up
And is encrypted to your headunit
Post #482710 5th Jul 2018 7:19pm
ASH
I was led to believe that the maps were on a hard drive??
Post #482711 5th Jul 2018 7:26pm
Card/hardrive yes, that’s what is in the top... Thumbs Up
Post #482725 6th Jul 2018 1:38am
