Home > Maintenance & Mods (L405) > L405 Grille options?
pld118
A wee mishap with the grille on ours means it either needs to be repainted or replaced.
The build sheet for the car shows the grille as being:
Front Grille : Grille-Dark Atlas/Dark Atlas Grille [064FE]
The car is santorini black (metallic flecks in the paintwork).
Apparently a lot of people just put a gloss black grille on even if the main car is Santorini black (does it not stand out)?
If changing the grillle or the colour of the grille should the bonnet scuttle be changed also (the car has atlas side vents and I’m not interested in the black pack, although would be interested in a santorini black grille either all over or mixed with the Atlas finish).
I might also stick with the current colour depending on whether it can be painted or replaced.
Damage pictured:
Post #482324 1st Jul 2018 10:44am
verydisco
This can easily be repainted, however, with prices for second-hand grills on eBay, it might be cheaper to simply replace it this way. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #482329 1st Jul 2018 11:32am
