Home > Technical (L322) > Dash menu service option
Kiamaria
I have a 2010 Range Rover vVogue built very late 2009/10. So the face lifted version with the horizon dash.
When i scroll through the menus on the dash the Service option is greyed out....... is this right and can it be switched on or not on this model.
Also I have just fitted a new Westfalia towbar with 13 pin electrics to replace the rusty Witter bracket that had 7 pin electrics, both plug and play with the Landrover lead.
Should there be anything illuminated on the dash when the caravan is plugged in?
Cheers guys
Steve
Post #481860 25th Jun 2018 7:29pm
the service menu is available if you only switch the ignition on and not start the engine... ... - .- -.
Post #481861 25th Jun 2018 7:38pm
mjdronfield
As Stan says.
Never had anything connected to my factory towbar, but from what I remember reading, is there not some control unit it connects to or some car setting that needs updating? My old memory might be wrong.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #481864 25th Jun 2018 7:48pm
bishbosh10
No lights on dash with a trailer /caravan hooked up but the little trailer symbol (bottom LHS of LCD screen) should flash in sync with the indicators. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #481888 26th Jun 2018 11:24am
