Home > In Car Electronics (L322) > Flashing stereo power button |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35438 |
this from our wiki might help,
19th Jun 2018 7:37pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
It all works ok, nothing frozen. just the flashing every few seconds is really irritation. 2011 4.4tdv8 if it helps, different unit from the 2006 model? 2011 RR Autobiography 4.4 TDV8 |
19th Jun 2018 7:55pm |
i've looked in the WM and done a forum search and cant find any relevance to your problem...
19th Jun 2018 8:14pm |
Cheers Stan. I will still check the connections and reseat them see if it does anything, might explain the rubbish bluetooth connection to Iphone though...although i don't have issues with android (bad interference during calls). Probably an apple thing. Also get a very bad DAB reception. 2011 RR Autobiography 4.4 TDV8 |
19th Jun 2018 8:28pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
19th Jun 2018 10:16pm |
StewD Member Since: 22 Apr 2016 Location: Glasgow Posts: 129 |
From the handbook...
19th Jun 2018 10:53pm |
Yes, only its not for a short while its constantly flashing, even after driving for an hour. 2011 RR Autobiography 4.4 TDV8 |
22nd Jun 2018 6:25pm |
Is there a way to upload a video? 2011 RR Autobiography 4.4 TDV8 |
22nd Jun 2018 6:36pm |
upload the video to youtube and then post the link it here... ... - .- -.
22nd Jun 2018 7:41pm |
22nd Jun 2018 8:05pm |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 235 |
I had a problem with the audio dropping out on my L322 and I think my light used to flash on occasions similar to your video.
22nd Jun 2018 8:27pm |
just guessing now but try unplugging any usb sticks you have connected and/or do a battery disconnection.. ... - .- -.
22nd Jun 2018 8:33pm |
No sound dropping out just the flickering light. Car is completely empty and no usb or audio devices plugged in, although I do usually have a ssd hard drive plugged into the centre arm rest usb. Due to go into a body shop after some tool took my mirror off which is why I’ve emptied it...might unplug the dashcam though see if that does anything. Failing that battery might be on the way out. It just catches my eye and is irritating. 2011 RR Autobiography 4.4 TDV8 |
22nd Jun 2018 9:08pm |
Think I've sorted it 2011 RR Autobiography 4.4 TDV8 |
23rd Jun 2018 5:36pm |
