Home > Technical (L322) > Rear suspension bags/shocks - how long do they last?
Mr Tee
Just put 2 shocks on the back of mine.100k 2009
Post #481424 20th Jun 2018 9:18am
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
Thanks gang! looks like i will leave well alone. I did the fronts on the weekend, It took about 6 hours all in all between cups of tea etc.
The big tips i would give are
Use an impact drill and socket set for doing the two big bolts that connect the strut and the hubs.
Do not remove either of the big bolts until you have both of them free.
Prepare the bolts with WD40.
I replaced the big bolts and nuts with new as mine looked pretty bad and I had feared i would have to heat them up. In the end a few thumps with a hammer set them free. The bolts i sourced direct from Land Rover and the nuts came from an agri engineering firm nearby.
Post #481904 26th Jun 2018 2:38pm
