Home > In Car Electronics (L322) > iPod connection - “Device error”
mike2013
I’d be grateful for any pointers on the following:
So... trying to connect a Bluetooth receiver onto the iPod connection in the 2010 4.4 Tdv8... and no matter what I do (and I’ve tried different cables in case of faults, and tried different receivers) I only get the following error:
I’ve been through all the posts here on the iPod connector, including the long write up about the tune2air/bovee 1000
In terms of receivers I’ve tried a couple of Bovee1000 units, in case I had a one-off fault, in addition to a couple of other models of 30pin Bluetooth receivers from amazon. But only ever the above error message.
Is there anywhere else I ought to go looking for the source of the problem?
Thanks for any suggestions!!! -- .. -.- .
L405 2016 4.4 SDV8 SE
Evoque 2016 2.0d HSE
L322 2010 4.4 TDV8 SE
Freelander 2 2009 HSE
L405 2015 4.4 SDV8
L322 2005 2.9 TD6
P38 2000 2.5 DSE
Post #481023 16th Jun 2018 12:03am
Mr Tee
Are you using the land rover cable to connect to the car?
Post #481031 16th Jun 2018 8:26am
mike2013
Yes.
I’ve tried an original LR cable. (And also several different models of other-brand cables). -- .. -.- .
L405 2015 4.4 SDV8
L322 2005 2.9 TD6
P38 2000 2.5 DSE
Post #481038 16th Jun 2018 9:11am
MAF260
I've just bought a Bovee 1000 for my 2011 L322. I had the same issue as the OP - device error and Spotify playing a split second of a song before pausing. Thankfully the remedy is very simple - your iphone hasn't got any music loaded to it, so isn't recognised. Download 1 song from itunes (a whole 59p!) and your Bovee will work faultlessly - all info displayed on the screen, steering wheel controls still work and even Waze coming through the speakers. I don't bother with the factory fitted navigation since downloading Waze as it's a million times better with real time traffic, speed cameras etc. It also runs Spotify through the app, so all my needs are catered for.
Post #490038 26th Sep 2018 6:43pm
Mtbr64
United Arab Emirates 2010 Range Rover HSE 5.0 V8 Stornoway Grey
Hero
Post #545490 28th Feb 2020 8:01pm
longd
What a simple but vitally important step I was missing !! 99p and I have music playing 🙏 thanks so much
Post #570943 26th Oct 2020 12:02am
Ianb4310
With the bovee how does everything come on the cars screen? I have a 2006 with the touch screen can I get the bovee working on the screen? I’ve done a search but can’t find anything conclusive
Post #570954 26th Oct 2020 7:44am
longd
Can only speak for 2010-2012... but on mine all the steering wheel functions work, I can skip tracks etc.
On the screen itself it has the name of the artist and song tittle.
My phone connects straight away as soon as I get in.
Volume and sound quality is amazing.
I did try an iPod 30pin to lightening adapter and it didn’t work. Bovee is fantastic if your model has an iPod interface then I would assume it will work the same, if you don’t have an iPod interface, do you have aux input ?
Post #570956 26th Oct 2020 8:02am
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Thanks for that i had deleted the apple music because it was set a the default music player and was doing my headin but not I've reinstalled it it should work like before Very Happy Very Happy
Post #594603 18th May 2021 1:48pm
Nev
United Kingdom 2012 Range Rover Vogue 4.4 V8 Nara Bronze
Said it before, this place is a mine of THE best info.
Bovee now working perfectly thanks to the above info.
Post #603476 11th Aug 2021 1:43pm
JayGee
About to ask this question about my new iPhone but did the sensible thing and searched first Thumbs Up 2012 TDV8 Vogue (L322)
Post #615718 10th Dec 2021 5:45pm
roel2018
Belgium 2017 Range Rover Autobiography SDV8 Carpathian Grey
Yes and finally my Bovee is working after 3 years:-) I was just thinking about the worst product that I bought last years but OK, now everything works perfect. I had the same Device Error message and 2 seconds preview. Just play 1 song in Apple Music.... Thanks @MAF260 2017 Range Rover 4.4 SDV8 Autobiography DPF - 100k miles - Dutch
Post #617065 21st Dec 2021 12:37am
JayGee
Also with an Iphone you can navigate your music on the car's touch screen which can't be done on Android although to be honest it's easier to do it directly on the phone itself. Still trying to work out how to stop autoplay every time the phone connects. 2012 TDV8 Vogue (L322)
Post #617084 21st Dec 2021 9:57am
T4ls
United Kingdom 2011 Range Rover Vogue 4.4 V8 Buckingham Blue
Thanks to all who posted here. Was getting seriously frustrated trying to sort mine. Forum to the rescue again
Post #675105 8th Oct 2023 5:35pm
