Home > Maintenance & Mods (L322) > L322 Audio System Melt-Down |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
I had similar problems when my Nav died.. graphic equaliser disappeared and the display changed to a blue screen with horrid fonts. Incidentally this happened just after I had changed the battery but was probably a coincidence as the post mortem on the nav showed serious corrosion and furing on the circuit board. Landrover now make a water shedder (do a search) to prevent water ingress. Basically a posh bag!
13th Feb 2011 6:23pm |
Soupdragon Member Since: 24 May 2008 Location: Norfolk Posts: 57 |
Thanks for the advice, much appreciated.
14th Feb 2011 4:38pm |
Pining down exactly what will be the problem..
14th Feb 2011 5:42pm |
