Home > Technical (L322) > vibration issue |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Torque Converter ?
8th Jun 2018 11:13pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
its defo not transmission or drive train related , absolutely certain of that pal , im going to have that wheel off again asap and renew the bit that had paly in it and see if that cures it |
9th Jun 2018 12:54pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
when You take wheel of make sure to clean all mating surfaces real well ( scape,send).
9th Jun 2018 2:50pm |
UPDATE , fitted a new lower hub joint on the NSR as it had play in it but ive still got the same issue , maybe not as frequent but defo the same fault , anything else I should look at guys ?? |
1st Oct 2018 12:42pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8590 |
Check rear brakes for excess heat.
1st Oct 2018 7:47pm |
it does this when I haven't even touched the brakes thow pal , it sounds a bit like when the suspension compressor kicks in , are the FF's known for the centre UJ on the prop shaft ?? it still puzzles me why its so specific to speed , if I bus along at 80mph , he's smooth and quiet , its really bugging me |
2nd Oct 2018 12:50pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
There are lots of threads on vibration, so a search might throw up some suggestions. These include injector problems and wheel weights falling off. I have a recollection that the Td6 was set up for 18" wheels and that bigger wheels could make it vibrate.
2nd Oct 2018 1:45pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
I have had the same thing for the last 3 years.
3rd Oct 2018 6:00am |
I paid specific attention while driving last night , if I keep it at 30 ish MPH I can defo feel it through the throttle / steering / my seat so Im going to have a look at the prop bearing this aft and see if its worn |
3rd Oct 2018 12:26pm |
well ive just read through a good number of threads mentioning a vibration , only one who found a cure said it was a faulty torque convertor , Im pretty sure that's not my issue , ive had a look an the prop shaft bearing and it doesn't look to degraded but I could move it with just the pressure of my hand , ive seen this bearing fail on other RWD cars and it creates the same symptom mine is displaying but as ever with an FF its not a 2minute job to change it |
3rd Oct 2018 6:15pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
Had same problem turned out to be a fault in a tyre .A bulge on the tread hardly noticeable to the eye except when on balancer plenty tread and looked ok thought it was coming from the front had them balanced not difference had back balanced and seen it on balancer new tyre and all was good .Not before I changed diff oils and transfer box oil hope all goes well |
3rd Oct 2018 6:24pm |
I checked my tyres already pal , they are / appear to be ok , im wondering if I can video the prop while driving , would need a remote camera I could mount underneath , there are plenty of place it could sit and I don't need to do more than 35mph hmmm . . . . . . . . . . . . . |
4th Oct 2018 6:18pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Eliminate the wheel/tyre by swapping with the spare. Then move forward to next item. Blunderbuss approach will not solve this. Defo ! .
4th Oct 2018 6:48pm |
Ok joe , will be methodical pal , i still find it odd that hardly anyone has found a cure for this , cant all be driving round vibrating all the while |
5th Oct 2018 8:14am |
