![]() | Home > In Car Electronics (L322) > New member old problem |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
Sometimes its just a poor connection - always worth disconnecting, checking & reconnecting all the plugs in the side of the boot area. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
have a try of the BT biro fix, if it works when you do that then probably the BT if its still broken then you've saved yourself the cost of the BT module.....
