Home > Technical (L322) > Chasing an idle issue.
alistairh
Cars always hunted if you try to hold revs at around 900rpm. Needles bounces about quite badly. It drives perfect but this has always annoyed me.
Smoke tested twice and nothing noticeable. Pcv system was renewed beforehand . Wondering if could be some sort of air leak in throttle body gasket that shows under certain load.what about throttle position sensor? Anybody solved similar
Post #480161 4th Jun 2018 10:32pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Reckon fuel pump is going. Well known for it. Mine went just like this with hunting needle etc. Easy to change. Only other thing could be the MAFF?
Post #480169 5th Jun 2018 6:46am
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
if this is the BMW V8, check the second "port" on the back of the OCV valve cover in the back of the inlet manifold. There is an open hose connector which should be blanked off with a small yellowish cup. If left open, it sucks in air, which condenses and causes all sorts of trouble in there.... water in lower elbow on PCV system, usually freezing up in winter time.
And it makes the lambda sensors go nuts wehile trying to regulate fuel/air mixture. You should be able to see such things on a live OSB tester.
regards
heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #480173 5th Jun 2018 8:15am
Danwilderspin
I will second this as this was my issue but the smoke test showed it Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #480458 8th Jun 2018 6:14pm
holidaychicken
Mine does it and has had new MAF, PCV and everything else but drives fine and idles very smoothly.
My PCV ports are blanked off, both of them I think.
Post #480491 8th Jun 2018 11:11pm
