Home > Maintenance & Mods (L322) > drive shaft front
reynolds
England 2004 Range Rover Autobiography Td6 Buckingham Blue
drive shaft front
just back fitted new front drive shaft boot having trouble getting drive shaft through hub any ideas please Big Cry
Post #49880 12th Feb 2011 6:26pm
It's a tight fit but if you can manage to get enough of the thread through then fit the hub nut on and pull it through by tightening the nut.
Make sure none of the splines are damaged before fitting or it will never go on
Post #49923 12th Feb 2011 9:00pm
