Home > Technical (L322) > Auto Headlights Problem
Dizzy Dee
Hi all.
I have just purchased a 2006 4.2SC as an upgrade for my 2002 TD6.
The headlights are a bit random on how they work.
With the switch Off/O on the switch, the headlights are on.
With it in sidelights they work on sidelights only.
With it on they work and with it on auto they are on all the time.
Any ideas where to start or look at?
Thanks in advance.
DD
Post #479740 30th May 2018 9:37pm
mjdronfield
Maybe someone has used a diagnostic tool to set them as daytime running lights.....
Are the rear lights on also when the switch is in the off O position?
Otherwise maybe the light sensor near the rear view mirror is faulty and it thinks it’s dark.
Not had this issue so I’m guessing....others who have had issues will be along soon....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #479741 30th May 2018 9:52pm
Dizzy Dee
Mmm
Thanks, I'll go and check the rear lights.
Post #479824 31st May 2018 6:54pm
Dizzy Dee
Rear lights are on in all positions of the switch.
Any more ideas?
IID tool on order.
Post #479835 31st May 2018 8:26pm
stu1
>IID Tool on order
Good move Thumbs Up
Post #479837 31st May 2018 8:33pm
Dizzy Dee
Just for closure on this one.
The Daylight runners were enabled! Rolling Eyes
IID Sorted that!
Now my next problem...
Post #489617 22nd Sep 2018 9:45pm
dolph34
If you have gone from a td6 to a 4.2 sc i would imagine the next problem is how to get the smile off your face Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #489618 22nd Sep 2018 9:47pm
mjdronfield
Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #489622 22nd Sep 2018 10:19pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
No, the next problem will be the S/c coolant pump. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #489628 23rd Sep 2018 1:18am
Dizzy Dee
Indeed Sir you will be right... and having done about 5k in it now I drive it every where I can.
I do about 35 - 40k a year for work so it's going to be one hell of a smile!!! Laughing
Post #489767 23rd Sep 2018 9:18pm
Dizzy Dee
Oh great!!
I've just done a rebuild of the whole of the rear suspension, as it squeaked!
Post #489768 23rd Sep 2018 9:20pm
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
I have the dreaded squeak too, did you manage to pinpoint it in the refurb?
Post #489956 25th Sep 2018 8:40pm
Dizzy Dee
I think it was the top bushes on the drivers side, on mine.
They were very tight when I started disconnecting things.
When I unbolted from the hub the top arm went upwards and didn't move, but until I started taking it apart I couldn't be sure.
Post #489963 25th Sep 2018 9:36pm
Dizzy Dee
Dizzy Dee wrote:
Oh great!!
Think it happened today! Started to overheat so I stopped and gotr the 'Big Yellow Taxi / Fuel saving device' home.
Something to look at tomorrow. Big Cry
Post #489964 25th Sep 2018 9:38pm
Dizzy Dee
Head gasket has gone! Big Cry
Post #490066 26th Sep 2018 8:25pm
