![]() | Home > General > Price check |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Hello Gaz and welcome along. I've had a quick look online at that car and it looks like a genuine example, with, as you say, very low miles. I presume it comes with the "proper" 2 year Approved Used LR warranty? You'd pay £140 per month (ish) to extend it so you're looking at £3k worth of warranty right there. Personally I'd be asking the following:
Gaz191062 Member Since: 21 Mar 2018 Location: Scotland Posts: 21 ![]() ![]() |
Cheers Counter of beans, thanks for your good advice there, much appreciated, yes its been a long few months trying to get a good one, most I have seen have had the rust on the wheel arches which has put me off a bit, only one had a bad tailgate but have picked up the bad points to look for so all a big learning curve, just wanting to get that odd one thats out there in top condition. Have contacted the garage and they are setting me up a test drive on Saturday, then I will be able to get a good long look over the points you mentioned and in particualr the arches and tailgate, just done an mot history check on the car and it has had a few advisories that have carried on throughout a few MOT's so tell tale sign of being run on a tight budget, nothing too serious but both rear sub frame bushes worn but not excessive play , light misting of oil on rear dampers ? and oil leak from engine, slight corrosion on brake pipe ferrules and a tracking issue, so without a doubt I would be demanding this is all put correct before even beginning to negotiate the price.
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Dealers must hate the fact that switched on people can check the MoT history and advisories online |
Yes, I have not even discussed this with them yet so will keep it up my sleeve lol |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
light misting of oil on rear dampers - pretty common on the adaptive dampers
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Check carefully the type of warranty given, even though it is main dealer supplied.
Thanks for the updates and info guys, regarding the oil leak being common is it an easy fix or big strip down required ?
Just had a look in the Wiki regarding the oil leak problem, if it is the two o rings then no big deal I imagine and will be a quick fix for the dealer.
Gaz sometimes - my theory mind - typical problems like the oil cooler housing or the alternator come up in the 70-90k miles range. My theory is that they are sorted by that milage. Check over the service history and see what's been done to date. If you can't see the invoices, ring the servicing dealer (from the stamps) and they'll prob. tell you over the phone what's been done. The brake lines should have been done on a TSB (tech service bulletin), possibly other items too.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6744 ![]() ![]() ![]() |
I’m not convinced that advisories on an MOT is necessarily a sign of a “tight budget” regime.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
It is on the high side, price-wise, but then someone has to pay for the warranty, and it''s not going to be the dealer! |
Hi, yes price is up at the top for the year, its the mileage that has drawn me to it on this occasion and if all okay when I see it and test drive on Saturday I will see if I can get a nudge on the price if I offer to take it.
Gaz, have you thought of posting a "wanted" ad on this site? I bought my car from a member on here and it was obvious he'd looked after it properly (cheers Ryan!). Just a thought. |
Hi Ryan, honestly never even though about that, spent all my time trawling garages and web sites as well, will pop an ad on and you never know, would be great to find something near by but saying that well prepared to travel for a good one |
