Home > In Car Electronics (L322) > Reversing camera RR Sport Vogue Disco etc
Lee Marsh
England 2006 Range Rover Vogue Td6 Zambezi Silver
Anyone experience or knowledge of these?
https://www.ebay.co.uk/itm/LAND-RANGE-ROVE...1438.l2649
Certainly in the frame price wise for anyone looking to replace rear view camera. Problem is it's 6 pin? My understanding is early L322's were 2 pin and the later L322 had a 4 pin connector?
The 4 pin plug from (circuit board) orig L322 camera fits the 6 pin, but in which configuration is not so apparent, as tried a few different rotations and nothing other than black screen comes up.
Probably not compatible with FF vogue regardless of description
Post #479486 27th May 2018 5:45pm
Those camera's are can bus driven so would be really difficult to use them anywhere else... They know which way up they are fitted, RH or LH and you can add or remove revering lines and pan in using them as mirror mounted camera's...
I would use a simpler camera if it were my choice sir Thumbs Up
Post #479489 27th May 2018 6:14pm
