Home > Technical (L405) > injector rails - interchangeable????
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
hi folks, I need a quick techy answer if any one knows...
for the SDV8 engine - Is the injector rail from the left bank interchangeable with the injector rail on the right bank? or would each injector have to be removed from the rail and swapped individually ?
thanks
Post #479350 25th May 2018 12:15pm
kiwirich
Australia 2017 Range Rover Vogue TDV6 Fuji White
Hey Fleagle_uk,
I'm not 100% sure but ...
The injectors are individual the rail on each side feeds the injectors on that side.
I doubt you can swap the rails over, I'd expect they have mounting tabs etc etc that make them fit their place only.
Someone with real knowledge will be along to confirm or deny shortly ...
Kiwirich
Post #480532 9th Jun 2018 9:40pm
Fleagle_UK
Yeah thanks for the info.
I forgot to update this post. I’ve since found out that the injectors have to be swapped one by one (with new seal kits for each one of course)
Cheers
Post #480535 9th Jun 2018 10:29pm
