Home > Technical (L322) > New (to me) L322 but whinning from trans? Issue fixed |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
If you suspect that it might be the transmission, and the noise is engine speed dependent, then there would be no harm in just checking that the fluid level is correct (only use Lifeguard Fluid 6 to top-up, of course). The seals on the connector sleeve were problematic on earlier models causing external fluid leaks, and the resulting low fluid level may cause the pump to suck air and cavitate, creating a noise. Probably optimistic, but maybe worth a try?
21st May 2018 11:13pm |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 |
My first thought was low fluid, not sure why but just a feeling. As soon as I got home I looked for the dipstick.....silly me, too easy!
22nd May 2018 7:07am |
Seems to more under hood towards the front of the engine, popped into our local specialist this morning and it is booked on Thursday for investigation......better start massaging my wallet!
22nd May 2018 12:46pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
I replaced all the belts and pulleys last year as mine made a bit of a whine when cold hope you get a good cheap fix |
22nd May 2018 6:45pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
On mine the air con belt tensioner bearings had run dry.
22nd May 2018 8:59pm |
At the Indie today, stripped down the front end a bit and found the tensioner bearing rough, the belt running off one of the idlers by a “groove” causing the idler to run off centre I guess, anyway new tensioner, idler and belt ordered to be fitted.
24th May 2018 2:38pm |
It was the tensioner bearing worn (very rough bearing), tensioner, idler and belt replaced........all quiet now, just the lovely V8 burbling along. David
25th May 2018 5:57pm |
