Home > In Car Electronics (L322) > New member old problem
Bobb
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Hi
New to this forum after having Luke D make me a key today.
I’ve once again got the flashing light and Range Rover logo on the head unit screen I can get into this and use the sat nav but everything else is dead, I’ve had new Bluetooth unit 18 months ago and just changed the amp but am thinking it’s the blue tooth again
Any other suggestions
Regards
Post #480368 7th Jun 2018 5:03pm
Sometimes its just a poor connection - always worth disconnecting, checking & reconnecting all the plugs in the side of the boot area.
Post #480370 7th Jun 2018 5:12pm
have a try of the BT biro fix, if it works when you do that then probably the BT if its still broken then you've saved yourself the cost of the BT module.....
http://www.fullfatrr.com/forum/post248518.html#248518[/url] There is nothing that can't be fixed with a hammer😜😜
Post #480522 9th Jun 2018 3:50pm
