Home > Technical (L322) > Super Super Extended Mode? Anyone tried this?
GGDR
He says it works on Discovery, Sport and FF's. Anyone tried it?
. Cheers, Greg
Post #453392 8th Oct 2017 9:21pm
its in the owners manual..keep your foot on the brake pedal and press the suspension mode button up...(or something like that) ... - .- -.
Post #453399 9th Oct 2017 6:22am
i was kinda right,
Post #453401 9th Oct 2017 7:31am
GGDR
Will definitely be trying that next weekend.
Will be quite useful in central London!
I'll just need a lump of 4x2 Cheers, Greg
Post #453405 9th Oct 2017 7:57am
It reads that its only available "If grounded and auto extended mode has activated" ....
Post #453414 9th Oct 2017 10:54am
GGDR
yes that's why the guy in the video is using a lump of 4x2 - it makes the car think it's grounded.
All very cool, I want to get some air under my FF! Cheers, Greg
Post #453426 9th Oct 2017 11:43am
^ I would say that stretching the bags will put extra load on any rubber that is starting to get brittle. Any minor cracks may tear. Seems daft to lose a bag for a bit of fun its only designed to be used in emergencies.
Grow up Whistle Rolling with laughter
Post #453431 9th Oct 2017 12:10pm
i agree with Gary...i've read a few previous threads on this and the consensus is that the bags 'could' potentially pop.... ... - .- -.
Post #453432 9th Oct 2017 12:36pm
GGDR
Aww you guys are killing me with your sensibleness 😀
Greg Cheers, Greg
Post #453440 9th Oct 2017 1:14pm
Laughing Thumbs Up ... - .- -.
Post #453445 9th Oct 2017 2:29pm
Observations:
He only put one piece of wood in the boot bag ?
No spinners on the wheels?
Would have thought super super distended access (bumpstop) mode was the coolest thing you could do to your LR in USA ? .
Post #453487 9th Oct 2017 4:17pm
GraemeS
Australia 2012 Range Rover Autobiography TDV8 Bournville
Raising the vehicle to maximum only requires higher volume of air in the air-springs, not higher pressures. If the rubber is brittle then its going to fail anyway with normal movement. However the compressor will get hot from working for so long.
Post #453523 9th Oct 2017 7:57pm
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Thumbs Up Thumbs Up Thumbs Up Very Happy Very Happy Very Happy
Post #454084 15th Oct 2017 1:12am
GGDR
Ground clearance in off-road height is 283mm
Does anybody know what the maximum ground clearance is underneath in super super extended mode?
. Cheers, Greg
Post #477340 2nd May 2018 10:09am
