Home > Technical (L322) > Lots of faults modules not communicating
GraemeS
Australia
A module might sometimes be drawing significant current whilst the ignition is switched off due to not shutting down when it should. I would check the voltage before starting when the faults show to see if the battery is low each time.
Post #484665 29th Jul 2018 9:56pm
Did you turn the steering wheel lock to lock after fitting the new battery ? .
Post #484670 29th Jul 2018 11:15pm
foptics
United Kingdom 2007 Range Rover Vogue SE TDV8 Giverny Green
No I didn't, should I disconnect the battery and do it again. Range Rover Vogue SE TDV8
Volvo S60 2011 D5 Auto
Post #484697 30th Jul 2018 11:14am
foptics
Also Check battery Voltage this afternoon, it's been stood since about 6.00pm yesterday and batt voltage was 12.4V. Range Rover Vogue SE TDV8
Post #484745 30th Jul 2018 5:14pm
