Home > Technical (L322) > 4.4 V6 key problem |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
Hi guys , car started making strange stepper motor type noises from the key area, so rather stupidly I sprayed some lubricant into where the key goes and now whereas it was fine before it now is almost solid and you have to turn ans wiggle the key to start it, it feels really solid when trying to turn the key. Any ideas? One day your life will flash before your eyes......................................make sure yours is worth watching!
30th Apr 2018 8:18am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
this from the wiki might help,
30th Apr 2018 8:53am |
Thanks Stan, it was fine until I put WD40 in the lock One day your life will flash before your eyes......................................make sure yours is worth watching!
30th Apr 2018 8:00pm |
roblane65 Member Since: 01 May 2017 Location: Newcastle Upon Tyne. Posts: 83 |
just for reference ,you should never use any type of wet lube on a key cylinder, lock or locking mechanism. Dry powder grafite from a locksmiths or good hardware shop usually does the job Range rover 4.2 SC 06MY. |
1st May 2018 6:59pm |
