Home > Technical (L322) > Help! Gasket cover change went wrong |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
It might help if you can show a photo of your problem.
29th Apr 2018 5:33pm |
Jmckenzie295 Member Since: 18 Apr 2018 Location: Glasgow Posts: 17 |
Apologies,.
30th Apr 2018 8:14am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35291 |
30th Apr 2018 8:48am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1252 |
Suggest a stud extractor? |
30th Apr 2018 10:06am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Long nose mole grips? |
30th Apr 2018 10:22am |
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 208 |
Have you got a couple of nuts of the same thread as the screw? You could try locking them together on the thread and then use a spanner on the lower nut to undo it - that often works. L322 TDV8 4.4 - current
30th Apr 2018 12:10pm |
What about one of those induction heater thingy's that Fuzz Townsend uses on Car Sosage? |
30th Apr 2018 12:12pm |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
for that, mole grips should do it no issue.. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
30th Apr 2018 12:55pm |
It wasn't twisting at first. But eventually got it with the mole grips.
30th Apr 2018 2:31pm |
All sorted, well one half done. Found a pipe that cracked and came off when starting, breather hose. So replaced and working fine.
30th Apr 2018 5:12pm |
