Home > Technical (L322) > Help! Gasket cover change went wrong
Jmckenzie295
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
So, I attempted the gasket cover change, however, . So I started to put the cover back on and replaced the bolt gaskets.
When tightening one of them, the part the bolt connects to has sheered off inside the bolt.
What do I do? I hope someone has an idea with this.
Cheers in advance
Post #477099 29th Apr 2018 2:46pm
Pawl
It might help if you can show a photo of your problem.
Gives more chance of possible solutions Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #477121 29th Apr 2018 5:33pm
Jmckenzie295
Apologies,.
See pictures. I have tried to grip the set screw and unscrew it. But can't get it.
Thanks again in advance
Post #477174 30th Apr 2018 8:14am
Post #477178 30th Apr 2018 8:48am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Suggest a stud extractor?
Post #477196 30th Apr 2018 10:06am
Paul thornton
Long nose mole grips?
Post #477198 30th Apr 2018 10:22am
Doonhamer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Have you got a couple of nuts of the same thread as the screw? You could try locking them together on the thread and then use a spanner on the lower nut to undo it - that often works. L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Suzuki Grand Vitara XL7 - sold
Mitsubishi Pajero 2.8 - part ex'd
Hyundai Santa Fe 2.0 td - sold
Mitsubishi Pajero 2.8 - sold
Post #477208 30th Apr 2018 12:10pm
PaulTyrer
What about one of those induction heater thingy's that Fuzz Townsend uses on Car Sosage?
Post #477209 30th Apr 2018 12:12pm
b348xyx
for that, mole grips should do it no issue.. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #477211 30th Apr 2018 12:55pm
Jmckenzie295
It wasn't twisting at first. But eventually got it with the mole grips.
All sorted, bought an M6 bolt and cut to size. So all back together. Started her up and very very rough on idle.
Spark plugs were not out, only coil packs. I presume putting coil packs back there is no need to put them back in the same slots as they come out?
Cheers
Post #477215 30th Apr 2018 2:31pm
Jmckenzie295
All sorted, well one half done. Found a pipe that cracked and came off when starting, breather hose. So replaced and working fine.
Not easy to get the rocker cover off or on when you have LPG due to the additional coolant hoses.
Other side will be next week, going to change the PCv valve and any hoses around it.
Cheers for the help again.
Post #477225 30th Apr 2018 5:12pm
