![]() | Home > General > What happens when you pull this !!!!! |
L7APK Member Since: 14 Jan 2011 Location: Lancashire Posts: 25 ![]() ![]() ![]() |
Not so, if your on a hill when you give it a yank ![]() |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
you should see where it is on an e65 bmw 7, you have to climb in the boot, with a really long socket thing |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
Its the emergency pull for the green plastic tab emergency pull just in in case that fails ...you pull both of them and the car deflates into its own briefcase.You can then carry it to LR for replacement of the emergency ring pull wire loop AND the green plastic tab. ![]() |
