Home > Technical (L322) > Webasto (Telestart) T91 with T91R remote compatibility
Blencoe
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
Hi folks,
You did such a great job answering my previous question I thought I’d throw another one out there.
My 2011 Vogue has a Webasto T91 receiver fitted in luggage compartment (boot) and a T91R remote control that does/will not sync when the procedures found on this forum are tried.
So to my question, is the T91R remote compatible with the T91 receiver, or does the “R” make a difference?
Any advise would be greatly appreciated, thank you.
Post #476783 26th Apr 2018 9:33am
try a new battery in the remote ... ... - .- -.
Post #476786 26th Apr 2018 9:45am
Webbie
Had the same issue, new battery worked for me
Post #476789 26th Apr 2018 10:03am
Blencoe
New battery fitted, still does the same multiple flashes of the light when trying to sync Sad
Post #477436 3rd May 2018 2:53pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Yeah I had that when programming mine recently. I'm sure I was doing something wrong when it came to programming it - I think I had I misread the instructions as holding the off button for 3 seconds rather than just pressing off within 3 seconds. I tried for ages one afternoon and had no success. Came out the next day and it did it first time, so I must have been doing something wrong, but I'm sure you aren't. Strange as I like to think I'm a reasonably bright guy but following 3 very basic instructions was clearly too difficult.
But will suggest if pulling the fuse isn't working, try just pulling the connection of the receiver and do it that way instead, but you have all the pieces to make it work, so you will get it to work. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #477454 3rd May 2018 5:55pm
or try and leave the process for a while to let the ecu's settle down..
maybe thats why it worked for you nick.. ... - .- -.
Post #477456 3rd May 2018 5:59pm
nicksaab
Thank you Stan for that vote of confidence! Wink Current Fleet:-
Post #477457 3rd May 2018 6:06pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Please someone correct if they have personal experience to the contrary, but I was under the impression that the T91r only works with the L405 and that you need the T91 remote for the L322.
(If that’s not the case I’d be interested as I need a remote fob).
Edit: I might be being stupid; perhaps the ‘r’ just means ‘remote’??? 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #477460 3rd May 2018 6:32pm
Blencoe
Chris_read my thoughts exactly.
This has now been concluded with a happy ending as new T91 (no R) remote purchased, first attempt at syncing it worked a treat.
So it is obvious that a T91R remote is not compatible with an L322 equipped with a T91 receiver.
Thank you all who posted replies especially Chris_read who confirmed what I had suspected. Very Happy
Post #477577 5th May 2018 12:39pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Well guys after trying to sync my remote purchased from fleabay and reading Blencoe post, my T91 Telestart is not compatible
with the T91R remote?
Anyone looking for a remote Big Cry
Post #498306 12th Dec 2018 2:52pm
drakes
Just a note for anyone looking for a reciever unit the T91R cannot be used on the L322 as it does not have an anologue output however the T90 and T91 are interchangeable as are the T90 and T91 remotes, I one of each both remote and reciever and all work fine. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #498356 12th Dec 2018 9:19pm
GraemeJudge
2004 Range Rover Vogue Td6 Java Black
so what remote will I need for a 2004 td6 heater please
Post #498358 12th Dec 2018 9:30pm
dmhort120374
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
Defo needs to be T91 not T91R
I have had the same issue, picked up a new T91 from Duckworth Dan £110 inc and problem solved.
Horts
Post #498359 12th Dec 2018 9:48pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
would the T91R reciever fit a 2016 L405 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #498360 12th Dec 2018 9:48pm
Tinman
Hi, Drakes PM sent
Post #498373 12th Dec 2018 10:22pm
