Home > In Car Electronics (L405) > Autowatch Ghost |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 788 |
LR’s stance on hard wiring a dashcam seems inappropriate and I would robustly test their opinion if required. Technically I don’t see any difference between accessing a live feed from the fuse box or a 12v socket, especially if you use a fused device that switches off the dashcam either after a fixed time or when the battery voltage drops below a predefined level. MY23 D350 HSE
26th Apr 2019 5:07pm |
fin Member Since: 20 Oct 2010 Location: South East London Posts: 51 |
After speaking with a reportable installer they tell me that the main difference is that the II is a unit made by someone else however the software is fundamentally the same, the II can now have 2 mobiles linked to it with two tags if you don’t want the app on your phone.
28th Apr 2019 2:45pm |
I too have the LR InControl Tracker App. The Meta Trak is a completely separate and additional system. No problems with it at all. It’s as if it isn’t there. The Meta App is great for monitoring various aspects of the RR including battery voltage. MY23 D350 HSE
6th May 2019 9:13am |
Lyonhead Member Since: 05 Aug 2017 Location: Cardiff Posts: 349 |
Hi Johnboy,
8th May 2019 11:21am |
