Home > Technical (L322) > Re-engine or scrap? |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
The diagnostic skills of your garage, or their ambition to extract max money from you, is questionable.
18th Apr 2018 12:53pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
+1 with kezbo, it looks like you are being prepared for the "haircut".
18th Apr 2018 1:28pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
Have they actually carried out a compression test? Alex
18th Apr 2018 1:53pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Wise words Nino. My first thoughts on the noise was loose sparks plugs letting by, but ruled it out as they did check the bores with a scope.
18th Apr 2018 4:50pm |
listened to it again and sounds not unlike cracked exhaust manifolds. Did it lose power and stop!!!
18th Apr 2018 4:55pm |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 |
Thanks for the suggestions so far. I can assure you that I'm not letting it go just yet, but always need to scope all possible options! It has certainly proved to be a more of a project then I was hoping it would be and I could have done without this for another 12 months, however now it's just a matter of sourcing the right replacement engine.
19th Apr 2018 8:16pm |
Ah!!! I'm guessing the heads are cracked then.
20th Apr 2018 7:34am |
Andy-B Member Since: 23 Mar 2017 Location: Todmorden Posts: 21 |
I had a P38 4.6 that sounded like that, it had blown a piece of the head gasket out.
20th Apr 2018 9:57am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
how are you going RR 2005 4.4 petrol
4th May 2018 1:20pm |
Hi Knares
7th May 2018 8:04am |
good to hear RR 2005 4.4 petrol
7th May 2018 10:02am |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
Hi David, have you thought about doing the chains and guides whilst the engine is out, just a thought. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie |
7th May 2018 10:54am |
I did think about changing the timing chains and guides, but as part of he pre-fitting inspection the garage found that the guides looked almost new with virtually no wear, so we decided to leave them alone. Unlike the old engine which looks awful in comparison (and not just the timing chains and guides )
9th May 2018 10:56am |
Well, found the cause of the engine failure!
12th May 2018 10:12am |
