Home > Technical (L322) > Throttle position bank reading iid tool question
kbald
Hi all just done a check and recorded the throttle position bank 1 and 2 sensors and they both remained exactly the same bank 1 at just below 9% and bank 2 at 4.34% except for 1 blip on this one when it spiked to 4.71% momentarily. I assume that this isnt correct and either means a faulty sensor or suck throttle body. Does anyone know if this incorrect or not though before i investigate further? Also are these sensors the throttle position sensors? Thanks Current 2007 TDV8 Vogue Buckingham Blue
Post #475599 12th Apr 2018 6:14pm
