Home > In Car Electronics (L322) > Is it possible to upgrade Bluetooth module for streaming
RikkiC 1976
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Hi new to L322,s just brought a 2009 TDv8 and wondering the best way to stream music via Bluetooth? Can a later Bluetooth module be retro fitted? Also can it be possible to upgrade to dab radio? Cheers
Post #475539 11th Apr 2018 10:21pm
Which 09 model do you have sir? 09 facelift with the TFT dash? If yes then it should already have DAB... Thumbs Up
Post #475542 11th Apr 2018 11:08pm
RikkiC 1976
Hi it’s the one previous to the last facelift. It’s actually built late 2008,registration 2009
Post #475614 12th Apr 2018 7:05pm
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Plus 1 for this topic - we've just acquired a MY12 TDV8 and I'm surprised that you can't stream music using Bluetooth.
Post #475629 12th Apr 2018 7:58pm
bishbosh10
Definitely cannot in the 12MY without an aftermarket gadget which is about £100 with the connecting lead. Bovee 1000 IIRC.
I was similarly unimpressed and as I am not keen on dropping £100 on a fix, I have resorted to a big USB stick which works perfectly in the cubby box USB port. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #475632 12th Apr 2018 8:06pm
NDT
Thanks Bish.
I might just stick to an aux cable then - we’re on Apple Music so can’t save music to a separate USB.
Post #475661 13th Apr 2018 7:44am
