Home > Maintenance & Mods (L322) > Exterior window trim bubbling etc
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Just wondering if these nasty black bubbly corroded trim pieces from along the top of the door against the window pry off easily and if so are they cheap from LR? I dont fancy the chrome covers to be honest.
T
Post #115135 27th Mar 2012 10:59pm
mjdronfield
I've done a bit of a thread about it here ;
http://www.fullfatrr.com/forum/topic10626.html
Not done mine yet though.
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #115163 28th Mar 2012 8:42am
tomthevet
Hey
I meant specifically the trim along the top of the door rather than the window surround though if that makes sense?!
T
Post #115178 28th Mar 2012 9:39am
Just buy replacements from Dan at Duckworths. They are an easy 10 Minute fit.
Post #115179 28th Mar 2012 9:41am
mjdronfield
No prob - I stoop corrected Smile
I knoe the thing you mean, at the top of the door, bottom of the window.
I need 1 of those - rest are OK.
I believe they are pretty cheap, and pull on / off.....
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #115221 28th Mar 2012 3:24pm
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I think what you are looking for is the weather strip.
Part number CGE500700 is for the front right hand side.
Part number CGE500710 is for the front left hand side.
Post #115226 28th Mar 2012 4:00pm
CUE99T
cool. might get one of two of those myself as it's the only thing that I see as issues on the car bodywork wise. all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #115228 28th Mar 2012 4:06pm
Should be four numbers re all four windows....
TRADE prices but retail must be close:
outer weather strips
Front doors �26.56+VAT EACH
Rear Doors �26.30+VAT EACH
-----Original Messa
Post #115231 28th Mar 2012 4:16pm
tomthevet
Cheers guys!
T
Post #115246 28th Mar 2012 6:19pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Just got 2 off Dan last week and fitted straight away ! Just gently push the old ones off from the corners - clean the dirt underneath - polish and then press the new ones on ! A 5 minute job Thumbs Up
Drivers side front door = LCGE500700 = �33.20
Drivers side rear door = LCGE500720 = �33.87
Dan will help you out Thumbs Up
Post #115261 28th Mar 2012 8:27pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
I have one window trim bubbling all across it. What's the part number, anyone? Rear left window. http://db.tt/lgXl4fJw Thumbs Up Thumbs Up
Post #115292 28th Mar 2012 10:12pm
EVOeng
Part number CGE500730 is for the rear left hand side.
Post #115482 29th Mar 2012 6:48pm
Lolo
Thanks, have ordered from Dan Thumbs Up
Post #115494 29th Mar 2012 7:28pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Prices have clearly gone up a bit.
LCGE500700 = £43.54 + vat
LCGE500720 = £41.95 + vat
These are discounted Duckworth prices!
Post #587768 17th Mar 2021 2:58pm
