Home > In Car Electronics (L322) > Ebay tracker |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
I was looking into GPS trackers and a few recommended a TK102 system. Seems to be around £10-£20 and you can wire it into the 12v supply. You call it (thanks Baltic ) for location and some versions of it have a movement sensor. If you link it to livegps.co.uk you can track it live on google maps.
7th Apr 2018 10:05am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3785 |
I fitted one on my Td6 and then moved it across to my 4.4tdv8 .
7th Apr 2018 10:32am |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 383 |
I use this type and it works very well...
7th Apr 2018 10:44am |
smudge68 Member Since: 27 Oct 2016 Location: UK Posts: 40 |
I use one of these, hidden in the dashboard and wired to a ignition 12v feed so it bursts into life when the car is started without draining the battery when the car is left standing for long periods. A PAYG sim card (a £10 top up lasts for about a year dependant on usage) and a lifetime subscription to GPS Live. I get a notification on my phone if the vehicle moves and the tracking seems spot on with mobile phone and desktop apps giving accurate location details.
7th Apr 2018 4:58pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 |
I had a TK102 device which I carried in my pocket when motorcycling** but stopped using it when the 2G network closed. It worked well. I had a cheap 365 day expiry SIM in it. One disadvantage was network coverage in some areas where I rode.
7th Apr 2018 11:09pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7966 |
That sent a shiver down my spine - and I guess explains your emoji |
8th Apr 2018 7:33am |
It does. His username on multiple fora was Bucko.
8th Apr 2018 8:17am |
