Home > Technical (L322) > Front left drive shaft
marshy
Australia 2002 Range Rover HSE 4.4 V8 Buckingham Blue
Morning all I want to no if a front left drive shaft from a 4.4I e53(31607503537) will fit into a 02 hse with same motor. I have looked at both parts and they look the same but I carnt get a proper answer from the pros so I have come to u the gods of l322 Bow down .
L322 part that looks the same is IED500120.
thanks chris 02 l322 4.4 HSE
Sitting on 20's
All in Buckingham blue
Post #474615 3rd Apr 2018 1:30am
bishbosh10
You are unlikely to find anyone who has done what you are proposing exactly so I doubt someone is going to categorically say they are interchangeable but if the part number is the same and they look the same it seems reasonable to give it a go!
You can always compare the two items side by side once you have removed the existing one. Then make a decision about which to refit! Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #474665 3rd Apr 2018 12:28pm
fisha
If you are that desperate, then as bishbosh says, have them side by side and compare.
Personally, I wouldn't bother my shirt even trying... a cheapo new one on ebay looks to be from £120 upwards. Second hand would be easily found too ... and that way you know they would fit ...
Heck, buy the £120 one, fire it in the car as that'll get you going again, sell the old on ebay for a few quid, walk away job done with no 'what ifs' in mind.
Whats the problem with your existing one ? V8 or else ...
Post #474849 4th Apr 2018 10:52pm
marshy
Thanks for replys but after looking the bmw one it won't fit different setup. To get a secondhand one here in Australia will cost double the amount of getting it sent over. Also I broke the one in the car so I carnt even sell it off lol. Big Cry the break is at the front diff end not wheel end. And all I did was drive out of the driveway. 02 l322 4.4 HSE
Sitting on 20's
Post #474854 4th Apr 2018 11:48pm
