Home > For Sale & Wanted > [Free] Rear light cluster (damaged)
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
I have a rear right hand light cluster from my 2010 L322.
The outer clear plastic is broken and much of it missing. Part of the grey plastic, some of which is hidden when fitted, is also broken. The lights themselves were working when I replaced the cluster about a year ago. It’s been sitting in the garage since, so every reason to believe that it’s still working. If you like, I can plug it into my car and check.
If this is of use to anyone you’re welcome to it. If no-one wants it, I will chuck it out next weekend.
You’re welcome to collect from me if you’re nearby. Home is Corsham, Wiltshire; work is central Bristol (very near Temple Meads Station).
If you’re not nearby I will send it by courier but I’d be grateful if you’d pay the cost of sending it. Should be about £8 to most places in the UK.
 Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #474581 2nd Apr 2018 7:53pm
GGDR
Can I take that Steve. I'll PM you now.
Thanks, Greg Cheers, Greg
Post #474604 2nd Apr 2018 10:00pm
steveball
Greg - you have PM. Current: 2010 Range Rover L322
Post #474692 3rd Apr 2018 3:47pm
