Home > Technical (L322) > Lower tailgate won’t open
rjff
Stormin
I don't think so but perhaps someone has done the job and could help.
Stan
Apart from injured pride and nothing else personal I hope, was there any damage to the RR?
Cheers
Richard
Post #475711 13th Apr 2018 2:22pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Well had a go today, pressed the button, whoooosh but not lowering of tailgate. Had a feel for the release catches and while pressing the button i could feel the catches moving but still no lowering of tailgate. So I hit the tailgate with my hand while pressing button and it released. Squirted some wd40 in and tried a few times and it now works ok, will put some oil in, in the next couple of days. I think it was the right hand side one that was sticking.
Cheers Thumbs Up
Post #475865 14th Apr 2018 11:43pm
tvrforever
I've had this start happening over the last few days in my MY12 Westie - press the tailgate button as the motors sound but doesn't unlock, press 4-5 times and the same, but then next press nothing at all. Start the engine press and motors sound again but only unlock about 25% time Sad
Last night I applied liberal quantities of WD40 to both latch sides, and after letting that soak in applied lithium white grease to the mechanisms - seemed to work reliably afterwards; will get proper test today with kid's sports runs...
/I thought my 2CV & TVR were my only cars to run on WD40 - JLR never cease to disappoint/
Post #475873 15th Apr 2018 6:45am
NailedOn
England 2012 Range Rover Westminster 4.4 V8 Barolo Black
millerj90 wrote:
Push down on the two hidden catches to release the lower tailgate.
Hi there folks. Newbie here. The lower tailgate will not open on my Westminster. I am unable to depress the two latches. Any advise please? My Land Rovers, so far:
Defender 90 V8 County
Disco V8S
Disco V8 GS
Freelander 1 TD4
Freelander 1 V6
RR L322 Westminster
Post #623032 9th Feb 2022 11:05am
mjdronfield
Hi, Welcome…
Other than squirting WD down the sides of the latches and trying to work them free, I’m out of ideas…. Suppose they are not actually in the down position already? But then I imagine you’d have difficulty shutting it, not opening… just thinking aloud….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #623034 9th Feb 2022 11:57am
NailedOn
Thanks for your reply.
The tailgate is up. I’ll give the latches a blast of WD40 and see how that goes.
Otherwise it’s away to my favourite Landie specialist.
Neutral My Land Rovers, so far:
Disco V8S
Disco V8 GS
Freelander 1 TD4
Freelander 1 V6
RR L322 Westminster
Post #623038 9th Feb 2022 1:01pm
mjdronfield
You will prob have to work them up and down a bit till they eventually free up.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #623040 9th Feb 2022 1:17pm
NailedOn
Smile The combination of WD40 and a spurtle tapped with a rubber mallet did the job. My Land Rovers, so far:
Disco V8S
Disco V8 GS
Freelander 1 TD4
Freelander 1 V6
RR L322 Westminster
Post #623153 10th Feb 2022 1:18pm
mjdronfield
Nice one. Think they get some of the crud as the tailgate gets dirty….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #623158 10th Feb 2022 2:10pm
