Home > Maintenance & Mods (L322) > EGR blank or delete?
Biggles1957
So being a bit dim here but what are the pros and cons of either just blanking the EGR or fitting one of the delete kits you see advertised? And any recommendations on make etc please?
Post #474399 31st Mar 2018 8:09am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I fitted this one, made from Alloy,
Nice piece of kit, however on my 2003 FFRR i get a negative deviation error code come up on iidtool BT after the egr delete.
https://www.ebay.com.au/itm/Range-Rover-TD...SwWWxY-Mw6
Post #474482 1st Apr 2018 10:10am
ilard
If you blank the EGR surely it will fail the UK MOT under new rules?
Post #474566 2nd Apr 2018 4:17pm
Paul thornton
If it's a TD6 then the EGR can't be seen without removing covers which MOT inspectors won't do.
Removing the EGR and replacing with a blank as shown above allows much better airflow plus stops loads of exhaust crud entering the engine.
TD6 's run miles better with it removed.
Post #474586 2nd Apr 2018 7:21pm
