Home > Technical (L405) > Seat belt warning sounds like strangled turkey
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
My MY2015 has just started making a very different sound when the seat belt warning bongs or if lights left on etc. It sounds a bit like a strangled turkey. Has anyone come across this before? I had just given it a fairly heavy power wash after getting mud in the wheel arches after going down a very muddy track. Could this be water in the alarm speaker? If so, where is it?
Post #474250 29th Mar 2018 1:56pm
i would have thought that the speaker is in the cab somewhere so it could be water ingress through the windscreen or bulkhead possibly. ... - .- -.
Post #474253 29th Mar 2018 2:04pm
jumpin mouse
Of course, it isn’t like the old horns under the bonnet but must be in the cab where it needs to be heard. Even more mysterious in that case. I can’t imagine that water got inside the vehicle.
Hopefully someone will have an idea on this.
Post #474254 29th Mar 2018 2:16pm
Chalky
You can disable the seat belt warning by doing the belt up 9 times one after the other. To re-enable do the same
Post #474299 29th Mar 2018 9:31pm
jumpin mouse
Problem solved. Maybe it dried out or fixed itself but we are back to a healthy bong.
Post #474455 31st Mar 2018 8:11pm
