Home > Maintenance & Mods (L322) > TDV8 Rear Shocks
Mr Tee
TDV8 Rear Shocks
So after the alternator was fixed, now have a leaky rear shock which is now thumping away over any bump. Priced replacements from Dan which are eye wateringly expensive >£300 each!
Been on tinterwbs and there are also Bilsteins listed at a lower cost :https://www.island-4x4.co.uk/rear-shock-absorber-l322-tdv8-bilstein-rpd500760-p-35443.html
What am I not seeing here? Listing states it will fit, any ideas why some are handed and others not?
Think the time is coming to get into a newer one, starting to feel like triggers broom maintenance is a few brakedowns away!
Post #474226 29th Mar 2018 9:26am
GraemeS
Australia
Does your vehicle have CVDs or standard shocks? CVDs are handed, standard are not.
Post #474230 29th Mar 2018 9:45am
Mr Tee
Ah Active Dynamics? Had to do the mod on the front strut tops so yup, it's the dearer ones Big Cry Big Cry
Post #474252 29th Mar 2018 1:59pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
ive just replaced mine from britishparts they had a deal before Wink Wink https://www.britishparts.co.uk/range-rover...rber-p5832 and what a difference from the oil filled oem Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #474257 29th Mar 2018 2:20pm
Mr Tee
That's basically why i'm getting confused, Dan quoted £309 each, so I'm worried that the £85 jobs won't fit.
Post #474259 29th Mar 2018 2:43pm
Scottyav
well they fit fine on mine give them a call they will tell you but yours id have thought were same as mine? and i have seen them more expensive on other sites Wink you can get them and check as they will refund and its worth the saving _____________________________________________________
Post #474273 29th Mar 2018 4:11pm
Mr Tee
Sounds like a plan, SWMBO almost wants a change of car into a newer one so any saving is a bonus cheers mate Thumbs Up
Post #474274 29th Mar 2018 4:16pm
CS
Hmm, when my rear shocks (2012) started leaking I was quoted about £80, but was then told on here that that would be relevant only to earlier cars, you might want to double check that what worked on a 2007 car will work on a 2010. Only Range Rovers since 1988
Post #474275 29th Mar 2018 4:48pm
Mr Tee
Roger that
Post #474277 29th Mar 2018 5:22pm
CS
Just by way of illustration, the Rimmer Bros website shows 'up to 2007' shocks at around the £80 mark depending on whether OEM etc and then later shocks at £270 or so. Only Range Rovers since 1988
Post #474278 29th Mar 2018 5:31pm
Scottyav
upto yes but as mine are after and the later ones like the link his should be the same,i had that as well when i asked you can get early for £80 on some sites but there to 2006 in reality,these are NOT for the early models these are for the later models Thumbs Up
'Range Rover L322 3.6 TDV8 2007 to 2009
Range Rover 3.6 TDV8 2010 to 2012 from vin AA000001 ' _____________________________________________________
Post #474280 29th Mar 2018 5:46pm
Mr Tee
Mine is a 2010my 2009 registered, tft dash so , think best to call and check before wasting time & effort
Post #474281 29th Mar 2018 5:50pm
Scottyav
Call them they list your year in the add, i spoke to them on mine last month and they reiterated to me these were for the later l322, my 4x4 indy charged me £140 to fit the rear shocks and the four front suspension arms Thumbs Up _____________________________________________________
Post #474284 29th Mar 2018 6:00pm
Mr Tee
Ok mate I'll give them a bell in the morning Thumbs Up
Post #474285 29th Mar 2018 6:16pm
GraemeS
Australia
CVDs were first introduced for MY10 and were standard on some configurations around the world but perhaps standard on UK models. CVDs were fitted to all MY11/12 vehicles.
Bilstein make a CVD version which are substantially cheaper than genuine and they have the external reservoir like the genuine.
Post #474297 29th Mar 2018 8:50pm
