Home > In Car Electronics (L322) > 2007 vse tv |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35439 |
it could be you are in a bad reception area so move closer to a transmitter or you might still have the old analogue tuner... ... - .- -.
25th Mar 2018 8:16am |
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 |
Is there a way to check what tv tuner I have fitted cheers |
25th Mar 2018 8:52am |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
You can certainly look at the label on the underside of the TV tuner unit which will tell you exactly which model it is - it's located in the left hand rear side compartment in the boot. But if you have RSE, don't think it's as easy to see or get at without removing the DVD changer and/or other pieces. |
25th Mar 2018 9:48am |
