Home > Technical (L322) > TD6 cutting power
Batpooh
United Kingdom 2002 Range Rover Vogue Td6 Galway Green
same problem
Hi folks i have a Similar issue Sad (TD6 2002) car starts and runs fine @ tick-over / low Revs but if i put it under any load it just bogs down Big Cry wouldn't pull the skin of a rice pudding, there are no dash warnings, iv'e checked the fuel pump fuses and replaced the fuel filter but not touched anything else yet, had my guy put his tester thingy on it and he said the fuel pressure was good (300 psi or something in that parish) and no related codes or the like. Any suggestions where to start? cheers Stuart
Post #474685 3rd Apr 2018 1:57pm
holidaychicken
You have low pressure and high pressure fuel circuit as can been on the link below
I would say you have a fuelling issue or turbo but I would expect to see some codes
Post #474755 3rd Apr 2018 11:08pm
wayneg
holidaychicken, Thanks for posting the live Data, I asked on another thread what good fuel pressure values should be, are these from a healthy running car. If so my pressure look good.
I am having similar loss of power issues as the op. Still not found the reason why. At least the car is drivable with a light right foot.
Does anyone know if the BMW x5 loom is the same as the TD6 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #475282 9th Apr 2018 9:05am
