Home > In Car Electronics (L322) > Reverse camera fault? (not the usual one)
benspray
Hi All
still going through everything on my new vehicle...
One thing that is annoying me at the moment is the rear view camera, which is broken at the moment so I get a black screen but thats another story and one for me to try and fix later....
The issue is it stays on when I go back to Drive or park and I'l pretty certain the other day that the reverse sensors continued to beep along with the black reverse screen even when I was back in park with the handbrake on... (reversed into a space, stopped on the beep, into park and handbrake on - still kept beeping...)
I have to use the arrow button on the screen to get out of the black reverse screen - anyone had this?
Whats perhaps also odd is my ccf was set as no cameras, set that to rear today and no difference.
its a 2007 btw if it helps.
As I now have the gap iid tool are there any live values/error codes to watch out for that may help figure out why its doing that?
Thanks all
Ben
Post #472474 13th Mar 2018 6:50pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Mine has the same delay in switching off the reversing camera and beeps. I think the RR brain in my '06MY is a bit slow. After all, it's getting on a bit.
Post #472477 13th Mar 2018 7:03pm
benspray
Ok thanks, I'll leave it alone next time I use it and see if it does go back to normal without me pressing anything Smile
Post #472479 13th Mar 2018 7:15pm
Gyre8
Yeah. I think I read somewhere it takes 15 seconds to switch to radio screen, etc. Although it seems longer on mine Confused
Post #472481 13th Mar 2018 7:18pm
Strider
Gyre8 Mine has the same delay in switching off the reversing camera and beeps. I think the RR brain in my '06MY is a bit slow. After all, it's getting on a bit
+1 It takes about 10 esconds to switch off and revert to the options screen.
Post #472485 13th Mar 2018 7:31pm
benspray
Cheers all!
Easy one then, perhaps I need to check the manual next time, just seemed an odd thing to happen Smile
Post #472488 13th Mar 2018 7:41pm
I think it does it because if you shunt forwards and backwards several times during parking, the screen just remains on the camera... Saves your screen changing to & from and probably getting stuck!
Post #472502 13th Mar 2018 8:41pm
