Home > Technical (L322) > Side repeater lamp glowing
B1ondini
Hi all, I have a strange one here. The side repeater on the drivers side wing has decided it is going to glow permanantly. It is at a low level, and won't flash with the indicator. It still glows when the ignition is off and the car is locked. I have taken the lamp out so I don't get a flat battery. Does anyone have any ideas? Thanks.
Post #471824 9th Mar 2018 5:15pm
change the bulb?
[take the near side out and swop to test] ... - .- -.
Post #471828 9th Mar 2018 5:39pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
A dodgy earth will do that too 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #471856 9th Mar 2018 7:40pm
B1ondini
Looks like I need to go tracing wires in that case.
Post #471861 9th Mar 2018 8:38pm
B1ondini
Had another look at this this morning, good earth at lampholder, lamp swapped but no different.
I measured the voltage at the lampholder and it is readung a constant 6.3v. This is with the ignition off or on, and with or without the indicators on.
Amyone any idea where I am getting a constant 6v from, and where I might need to look to sort this?
Thanks.
Post #472120 11th Mar 2018 12:20pm
Grofus
Lights control module?!!!
What year and model do you have? 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #472127 11th Mar 2018 12:56pm
B1ondini
2007. Any idea where the light check module is?
Post #472131 11th Mar 2018 1:06pm
B1ondini
"The LCM is located on the RH 'A' post, behind the trim panel"
Post #472134 11th Mar 2018 1:11pm
